Posted · Feature Request: All air-exposed walls to be considered outer walls
Right now it seems that only walls that are truly on the most external surface of the print are considered outer walls.   For instance,  if I were to print a tube, only the walls external to the tube are treated as outer walls, while the air-exposed walls inside the hollow tube are considered inner walls.  I propose that all air-exposed walls be considered outer walls (or have an option to do so).
    I don't understand what you mean. If you print a tube, the walls exposed to air on the inside are considered to be outer walls. Do you have a project file + image that shows the problem?
