Switching layer height +-0.06mm between files of the same work and just found why my profile configurations got modified "by themselves".
My bad I didn't read (thought I was just overriding current settings with old ones, not Updating my profile), but I still find it an awful workaround creating a new profile. (No rollback, one missclick and I lose my base profile)
I mean for just one work I need 4-5 profiles -minimum- because of small changes?....or maybe shuld I memorize every little change? Come on guys, counterintuitive
4n0nyM 2
Thank you for the quick reply.
I know the function so far, but maybe I'm missing something. For example, I save a file as a project where I have carefully thought about the fill, support settings, walls, etc.. However, I have a retract of 1.2mm there. After some time I then want to print the object again and therefore import it as a project in Cura. In the meantime, however, I have optimized the retract and set it to 0.8mm. After importing, however, my profile is overwritten and the retract is set to 1.2mm.
Why isn't the value simply entered without overwriting the profile, so that I can simply press the reset arrow?
So that it looks like this, for example:
The same is true for the Start G-code. Without overwriting it permanently, I would find a temporary overwrite, with reset arrow much better.
Cuq 205
Hello,
That's a different request from the initial demand. But on this point I'm totaly agree with you. It's almost impossible to know what have been modified and if you say "Update", your profile are automaticaly updated whitout any option to get back the initial state. So by security you prefer to create a new one and after a while you have dozens of profile #1 #2 #3.. But you don't know what is the real good one. Profile management in Cura sucks ! 🙂
Thats Why I'm not using it 😢
Edited by CuqLink to post
SionSR 0
I too find the project management confusing. It would help me if I could edit the .3mf files without using the GUI. Is there a Python add on that can do this?
Hacking the g-code is laborious.
