Thx for the feedback. It is annoying- 🙂.
I wonder what the conditions are that trigger the infill lines to be "skipped over, then retreat and filled in..." Complicated I'm sure!
I do have Z-hop enabled and using 0.4mm. Here:
I'll enable "Connect Infill Lines" and see if "the grind" is reduced.
GregValiant 1,364
I've never found it to be a problem that shows up in a print. It can be noisy and annoying though.
Have you tried enabling Z-Hops? The default is .2mm but I've found that at .5mm it will go over most little pimples and things that might stick up above the working Z height. The actual setting name is "Z-Hop when retracted" so the Retraction Minimum Travel and Max Combing distance must be set correctly or a retraction won't happen and consequently a Z-Hop won't happen.
You might also try Connect Infill Lines. I like that one because it really cuts down on the number of retractions.
