GregValiant 1,035
You should switch to the Arachne Engine Beta II version of Cura for this model. It is capable of filling in the middle "third" wall.
With the current version set to two walls consider a capital "I". The vertical leg of the letter has two walls on the left and two walls on the right for a total of 4 walls. If the vertical leg is 1.2mm wide then 4 walls won't fit and the center remains empty unless you use "Fill gaps between walls = Everywhere". Essentially, the program only does an even number of walls across an object.
1
JoeJoe 0
oh also, i tried setting line width to .35 and to .30 and that change did nothing, still only doing 2 walls instead of what should now be 4. I am very confused.
