Strange ironing path
sidney85
Posted · Strange ironing path
Hi all,
I'm a new user to Cura, before I was using PrusaSlicer. But I really like the support generation in Cura. The supports are so much cleaner and easier to remove.
But i'm having a little issue with ironing, I don't see any logic in the ironing path that Cura follow's. Selecting Monotic Ironing doesn't make a difference. The left side of the prints is good, but for the right side it makes an unnecessary hop (both sides are equal only mirrored). That wouldn't be a problem if I didn't make any scars, unfortunatly it leaves a mark on the right side.
When I change the setting Top/Bottom Line direction to [90] this also effects the ironing path. In a good way because than the top is OK. But this 90 angle also effects the bottom and that give  other problems with strenght of the model.
I was wondering if someone know's why Cura is making this strange path with the default ironing options? I've attached the gcode file (only the top part)
TEST.gcode
        • 24 replies
