There aren't many printers that need the X, Y, or Z calibrated.
What I usually do is clean up the surface by giving the cube a couple of strokes with a 10" mill file. That is enough to knock off any high points that might be getting in the way of the calipers.
A setting you could try is "Coasting" in Experimental. It can cause problems with the initial prime after a retract and a long combing move, but on that cube it won't be a problem.
1
GregValiant 1,342
