Ultimaker Cura backup restore at fresh installation
Posted
· Ultimaker Cura backup restore at fresh installation
2 hours ago, alwwwex said:
and looks like it can be repeated - after fresh installation of last Cura on blank system (new PC), there is no option for restore backup at start - you need select at least one printer (even after sigh in dialog), only then, its possible to go backup restore plugin and select backup.
But then I get second problem - Cura closing, but when I start Cura again (normal restore procedure), there is again "Add a printer" dialog, and there is no way
Could you report this issue on github?
I think this is caused because the preferences arent correctly restored. So it seems to still be loading the old preferences, which is pointing to a machine that doesn't exist anymore. Since it can't load anything, the "add a printer" dialog pops up.
nallath 1,124
