On 2/22/2022 at 11:09 PM, YetiScout said:My printer isn't on the preset options. I attempted to use a different preset option but it but it didn't work. I believe it might have something to do with the G Code but Im Not sure. Using another preset, it prints the very first layer and then it stopes extruding, but the printer keeps moving. Any help would be greatly appreciated.
hello! I have the same printer and the same problem, have you found a solution?
GregValiant 1,364
Post one of the gcode files that came with the printer, and post a gcode file that you created yourself (one that doesn't work). Maybe something will stick out. It has a 3-in-1-out hot end - is that correct?
Have you loaded the "Printer Settings" plugin from the MarketPlace? It has two setting you need to enable if it is a 3-in-1-out printer. The settings are "Extruders Share Heater" and "Extruders Share Nozzle".
