Posted · Very little extrusion of the first layer
I am using Cura to slice a simple cube. The extrusion amount of the first layer is extremely low, but the other layers are fine. I copied the first 2 layer g-code here, and I would like to know if anyone have an idea to solve this issue. Many thanks!
;FLAVOR:Marlin
;TIME:40
;Filament used: 0.00241245m
;Layer height: 1
;MINX:11.501
;MINY:10.725
;MINZ:1
;MAXX:30.501
;MAXY:29.725
;MAXZ:5
;Generated with Cura_SteamEngine 4.13.1
M82 ;absolute extrusion mode
G28 ;Home
G1 Z15.0 F1800 ;Move the platform down 15mm
M302 P1
M83 ;relative extrusion mode
;LAYER_COUNT:5
;LAYER:0
M107
;MESH:20x20x5.STL
G0 F1800 X30.501 Y29.725 Z1
;TYPE:WALL-OUTER
G1 F600 X11.501 Y29.725 E0.00745
G1 X11.501 Y10.725 E0.00745
G1 X30.501 Y10.725 E0.00745
G1 X30.501 Y29.725 E0.00745
G0 F1800 X30.001 Y29.725
G0 X29.501 Y28.725
;MESH:NONMESH
G0 F600 X29.501 Y28.725 Z2
;TIME_ELAPSED:9.395881
;LAYER:1
;TYPE:WALL-OUTER
;MESH:20x20x5.STL
G1 F600 X11.501 Y29.725 E0.14892
G1 X11.501 Y10.725 E0.14892
G1 X30.501 Y10.725 E0.14892
G1 X30.501 Y29.725 E0.14892
G0 X29.501 Y28.725
;MESH:NONMESH
G0 F600 X29.501 Y28.725 Z3
;TIME_ELAPSED:17.311875
    16 hours ago, GregValiant said:
    You have looked at your Initial Layer Flow %?  The flow of layer 0 is just about exactly 5.00% of the flow shown in Layer 1.
    Thank you so much, that solved the issue!
