Awesome, thanks Greg.
The filament guide pulley is one that caused issues yesterday. I just resliced and checked it and its doing the exact same thing-head moves right along the very front of the bed, hits the glass bed clip (that is outside print area) and then prints everything in one line along the very right hand side of the bed, like it thinks the print location is somewhere further to the right of the printer bed. Home is front left corner. Home is set correctly in the slicer, and other files that work properly print exactly where I set them to go in the slicer
As I mentioned, each different downloaded file has a different issue, but they are all doing something wrong
I've thrown in the keychain one just so there is something different to compare to. Downloaded this just as another test yesterday. This one raised the Z axis right to the top before I cancelled the print. I haven't checked if this one is printing different when resliced, but all the others did the same thing wrong each time it was resliced so I'll put money on it being the same as it was yesterday
Appreciate the response, thanks
GregValiant 1,342
Load a model that has been a problem. Set Cura up to slice it. Use the "File | Save Project" command and post the 3mf file here. It will have everything in it and is the best for troubleshooting.
