22 hours ago, GregValiant said:It's odd that they aren't marked. I would guess a .2 and a .6 but guessing can get you in trouble. If you received a cleaning needle with the printer then it should just barely fit through the .4, it won't fit at all in a .2, and it will rattle around in a .6. Does that mean they aren't a .3 and a .5? Nope. Using something with a known diameter as a go-nogo gauge will give you a closer idea.
Yep. I'll try to measure with my digital caliper, but 0.1 accuracy might be a bit challenging.
I've ordered a 0.6 and a 0.8 nozzle, so I will try to compare with the ones I have.
It's indeed strange that they aren't marked, and there is no documentation whatsoever with the printer.
GregValiant 1,490
