Posted · test di stampa
Buongiorno, sarebbe possibile prima di iniziare una stampa, effettuare un test di prova per verificare che i filamenti escano in maniera corretta? per evitare che si cominci una stampa complicata e ci si accorga dopo che il pva non esce correttamente.
grazie.
Maurizio
    Posted (edited) · test di stampa
    Some printer definitions include "purge lines" that print before the actual model starts to print.
    In Cura you can enable a "skirt" or a 'brim" that goes around the model and is for the same purpose (to get the plastic flowing).
    Edited by GregValiant
    If it is an Ultimaker printer then someone else will have to respond as I don't know them.
    If it another brand of printer you can add something like this to the StartUp Gcode:
    G92 E0 ; Reset E
    G28; Home XY axes
    G1 Z10.0 F3000 ; Move Z
    G1 X1.0 Y20 Z0.3 F5000.0 ; Move
    G1 X1.0 Y200.0 Z0.3 F1500.0 E15 ; First purge line
    G1 X3.0 Y200.0 Z0.3 F5000.0 ; Move
    G1 X3.0 Y20 Z0.3 F1500.0 E30 ; Second purge line
    G1 E28 F1800
    G92 E0 ; Reset Extruder
    The purge lines above run to Y=200 and would need to be adjusted if your bed isn't that big.
