Hi GregValiant,
Thanks for the response.
Yes I have Printer setting plugin, with the correct nozzles settings as per your para above.
A20T is a triple filament single nozzle. I have set all mateerials I'm using to 205 matching their normal print temp.
I've searched all the setting on the advanced panel to see if I can find this 215, not showing anywhere.
Not sure why i would have to ChangeAtZ as I have a fixed temp throughout print.
Also this ChangeAtZ is the 5.3 experimental one on my system.
It's still stuck on 215C.
I have this running as print via the USB, would that make a difference?
Regards
GregValiant 980
If you haven't done so - go to the Marketplace and load the Printer Settings plugin. Within the Printer Settings are "Extruders share heater" and "Extruders share nozzle". I recall that the AxxT printers are 2-in-1-out printers. Cura needs to know that.
You may also have to create custom materials. A normal situation with separate dual hot ends would be for the inactive hot end to cool to "Standby Temperature" so it doesn't drool. Your custom material could be altered so the Standby Temperature is the same as the Print Temperature.
Once you have that sorted out you will need to tell Cura when to change temperatures. The ChangeAtZ plugin is the tool for that. Go to "Extensions|Post-Processing|Modify GCode|Select Settings|ChangeAtZ". You would need an instance for every temperature change. The first might be "change at layer 25" and the second would be "change at layer 40" and then "change at layer 55", etc.
