Hi, and thanks for your quick response.
I will definitively try different USB Ports. Maybe that works.
But how do you get to the following conclusion?
On 3/15/2022 at 12:56 PM, GregValiant said:The Octoprint/RaspPI combination seems to work well
On the Projekt Website they don't even mention the XYZPrinting Devices - neither for being known working nor not working.
Thank you
GregValiant 1,490
This seems to be a popular problem with the DaVinci printers. Most searches come back with answers regarding Windows issues, but the same thing may be going on with Linux. One fix that worked occasionally was plugging the printer in to different USB ports in the computer and then all of a sudden things came to life. That would seem to indicate that the port driver only installed on one port rather than being available on all of them.
The "cache" size seems important as well. Connections have been made with the DaVinci at a baud rate of 250k. That is one of the rates that Cura checks. FYI - it looks like Repetier Host has the same problem with the DaVinci's.
Since no Ultimaker printers use USB printing anymore, it is unmaintained unless someone from the community wants to take a shot at updating it. The Octoprint/RaspPI combination seems to work well.
