I think that is not the case hier, I think you misunderstood the Problem, beside this it is a clean cura 4.13.1 install. Print profile for both cases is normal. But for the sake of pleasing you, her are the 4 variants.
Thank you for your efforts.
Regards
Ksanto
Anycubic Chiron - Normal - Owl-Filament Black.3mf Anycubic Chiron - Normal - Test Dimater Max.3mf Ultimaker S5 - Normal - Owl-Filament Black.3mf Ultimaker S5 - Normal - Test Dimater Max.3mf
Edited by Ksantotypo
ahoeben 1,770
Values in the material can be overridden by what you set in the "sidebar", or in a custom quality profile.
If you save a project and post a link here, we can see if that is the case.
