This has been talked about here recently. I think if you search for "shrinkage" or "scale factor" you may come up with something.
One of the settings that is "hidden by the active machine" is "Scaling Factor Shrinkage Compensation" which would seem to be what you are looking for. (I think it would need to be a function of the Material you are using?)
Edit: One of the settings under "Preferences | Configure Cura | General" under "Opening and Saving Files" is "Select Models When Loaded". Checking that should make a tool on the left side popup (probably the last one used?). At least you would have a reminder to set the scale and maybe the Z location.
GregValiant 1,342
@nallath of the Cura Team may comment on that.
