PLA problems with first few layers
Frankini
Posted · PLA problems with first few layers
Hello,
I own a "geeetech a10" and for some reason the first few layers of the print are messed up and as if it's not sticking perhaps.
On the bedplate is a mess, I've then tried to print a raft which is perfect until it starts printing the part, which still presents the same first few layer issues...
Is it a model problem?
I feel it's trying to print it just slightly higher than it should, but I've no idea.
Another thing is that I've enabled z-hop but continues to scrape the print every time, raft included.
I'll include pictures of the raft and the print below.
Print speed: 30mm/s and 60mm/s with no difference.
Bed temp: 60°C, 70°C and 50°C with minimal difference.
I've leveled the bedplate, I've tried different layer thicknesses but nothing of help.
It printed the example gcode flawlessly, so is it a setup problem? Software problem? Bad printer profile on ultimaker cura?
Hope someone can help shed some light on this issue.
Thank you in advance
        • 24 replies
