Creating Custom Material Profiles
aforww
Posted · Creating Custom Material Profiles
Hello all,
I'm trying to organize my Cura 4.13.1 materials and and profiles a bit better but I'm having some trouble.  As an example, I have created a material (Overture TPU) and it shows up in the list.  However,  when I tried to import the profile I have saved under the "Generic TPU" material, it gives me the following message:
"Successfully imported profile Overture TPU Profile.
Warning: The profile is not visible because its quality type 'standard' is not available for the current configuration. Switch to a material/nozzle combination that can use this quality type."
It's a .6mm nozzle.  How or what do I need to define to get this to take?  Thanks in advance for your help.
