Hi Thank alot
please see attached only thing i altered different from the 0.48 layer is just the layer height to 0.2mm
i have the same set up at work (cura with an ender 3 pro) i tried the exact same thing 0.48mm layer height print and then alter the layer height to 0.2mm and both printed no problem
so not sure what ive done here 😞
GregValiant 1,342
Set Cura up with that calibration cube and ready to slice. Use the File | Save Project command and post the 3mf file here. Post that gcode file as well.
