Ultimaker Cura Settings for a BiQu BE1 SE Plus Printer
Posted
· Ultimaker Cura Settings for a BiQu BE1 SE Plus Printer
You need to get with BiQu and find out if they have a Cura printer definition file for your printer. You could install the smaller B1 in Cura and then make adjustments to the Machine Settings (build plate size) but the B1 does not come with Auto-Leveling. You would need to find what command the printer uses to call up the auto-level routine and then you need to add it to the StartUp Gcode (also in Machine Settings).
GregValiant 1,364
helakejr 0
Included on the provided SD card is a cura folder which contains the instructions for creating the BiQu B1 SE Plus printer. Also available on github.
