Thanks GV,
I've attached my gcode - it's not exactly the same as the object in the photo as I don't have that gcode any more, that was a smaller test print of a larger object. I've attached the gcode for the new object though the Cura settings are all exactly the same. Just the object is longer now.
Z-hops are off, I've not touched this since installing Cura, the x-axis is solid, no wobbles or jams in anything there. I'll take a look at the Y axis rods etc though in general the print quality is perfect, the sides of the prints are 100% fine its only the top layer(s) I'm having this issue with.
Edited by Sonic3389
GregValiant 695
Post the Gcode and I'll look at the E numbers. In the mean time, check your Z mechanicals (coupler, threaded rods, wheels, X beam is rigid, etc.) . Extrusion problems like that can happen when the Z gets dirty or hangs up instead of moving to the new position.
Did you have Z-hops enabled?
