58 minutes ago, GregValiant said:Taking out the nozzle and putting it back in may have changed it's height relative to the "trip point" of the ABL sensor. A quarter turn is .25mm and that can make enough of a height difference that it affects bed adhesion.
Try adjusting the Z offset in the printer to move the print head down closer to the bed. Try 0.1mm at a time. I don't have an ABL so I don't know if you will be adding or subtracting.
I think that is something you will have to revisit every time you clean the nozzle or change nozzle size.
Thanks for the info. I did manually move the Z screw rod up in-order to make it easer to unscrew the nozzle so I could clear the nozzle. I guess I didn't screw the Z rod for the nozzle down far enough. Though I don't know how to tell when I hit the limit switch. I am still learning the whole process of 3D printing.
Edited by reble
GregValiant 1,492
