Easy plug in 3-point bed leveling
Posted · Easy plug in 3-point bed leveling
Hi everybody...
what should I say... I love it when a plan comes together...
After a long time planning and struggling around with pro & cons I finalized my alu bed with 3-point bed leveling-project.
Here we go...
First I created repacements for the original bed leveling things and a new additional thing for the middle position in the back. The nice thing: no nuts any more as there are printed parts below the wood to secure it
Second, I organized a nice 5mm thick alu plate :smile:
Next, print all the necessary stuff and disassambled the original bed.
I drilled a 8mm hole in the middle of the back mounting positions and started assambling the whole thing...
And now - look at the pics... untested under printing conditions, but nevertheless looks awsome and works like a charm... Sorry, but I'm a bit proud... :smile:
Here are a few pictures:
IMG 0736
IMG 0733
IMG 0735
IMG 0734
IMG 0738
The printable parts are available at http://www.thingiverse.com/thing:247552
Unfortunately there is just one issue left - my problem with wood glue printing at glass (there are some another posts helping me to fix this issue)
Next things:
  • Add a nice silicone heating pad with a nice cable chain (gues there is one who might know... :cool: )
  • Replace original wood arms with milled alu arms
... but that´s another story... :smile:
    The arms are left from a previouse trial and honestly I was too excited of the new solution and forgot to disassamble them.
    Unfortunately the setup I used them was not stiff enough so the plate itself was wobbling.
    • 2 weeks later...
    I changed my bed leveling also to three point, but I have one screw in the front and two on the sides.
    I also installed a heated bed, but no Alu plate yet.
    What are dimensions of the Alu plate? 220 x 220? Or a little bigger? What type of Alu is it the famous Mic-6? Mic-6 is hard to get in Europe, but after longer research and talking to specialized metal traders I found sth. which has the same quality and spec like Mic-6.
    It´s called 5080 or 5083, you can buy it online here:
    http://www.metall-kunststoffhandel.de/shop/aluminium-feinstgefrst-p-2134.html?osCsid=3a7f6797d76f68961e0ed88693b46260
    What type of silicone heating pad will you use? Do you have a source in Europe for it? All sources I found are in China or the US.
    By the way, I like the printed cable chain you made for the heated bed. I think I will print one too.
    I only used a Alu plate which we had in the company - honestly no idea, but it is nicely flat :smile:
    The dimensions I used is the same as original (242x242) - there is a pdf at my thingiverse description also with all dimensions.
    MIC6 plates you can get here, but as this is a TM, it is sold via ACP6000.
    http://www.werner-weiss-gmbh.de/ACP6000.htm
    The silicone heating pad is shot on ebay - at a UK seller.
    http://www.ebay.at/itm/281073796785?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
    Unfortunately I had no time up to now to mount it - and there is still the relais and the PSU missing :smile:
    Regarding cable chain, thank you - I placed it in the UM, you can find a picture I made yesterday in my other post.
        • 21 replies
