Posted
· Advice to update a "Tool" Qml plugin file
As usual @fieldOfView your analyse is very acurate. Yes I feal this PyQt6 import not very elegant. But if there is no other simple solution... I will use the french expression : Choose between the plague and the cholera ... I will take the plague
Thanks for your feedback ...
And it's not because I update my plugins that I will make them available on the marketplace. I think I'm still waiting for a stable version of Cura 😄
Cuq 205
As usual with me : it's not clean but it's working ... Any advice for a better or more elegant solution ?
ahoeben 1,963
If you dislike the unused import, you could use the Cura version instead:
cura_version = Version(Application.getInstance().getVersion()) tool_panel_path = "resources/qml/MeasureTool.qml" if cura_version < Version("5.0.0") and cura_version.getMajor() > 0: tool_panel_path = "resources/qml_qt5/MeasureTool.qml"
But then you need to import UM.Version and UM.Application. Choose your poison.
(good to see that you have decided to update your plugins afterall)
Cuq 205
