Ultimaker Cura Error
AD1968
Posted · Ultimaker Cura Error
Morning all,
Ive been using Ultimaker for a few months now with my dremel printer and it works very well. However Im now getting this zero minutes to print and zero filament used  when ever i try to slice anything. Its a little frustrating. I've reinstalled version 4.13 but gives the same result. Im sure its something blindingly obvious but I cant see what changed?
What am i doing wrong?
Thanks for your help.
Kind Regards,
Andrew.
    It looks like this is an extremely thin model. Cura 4.13 will not create toolpaths for things that are thinner than twice the line width.
    You can try the Cura 5 beta, which handles thin walls in a superior way, you can try lowering your line width, or you can use the "horizontal expansion" setting to make the model thicker.
        • 30 replies
