Hi Greg, thanks for your response.
I'm a bit confused - but I'm very tired, so apologies.
Fistly; I meant to put the part about "rounding error" after the zig-zag - since it does not make *all* walls a zig-zag, even the same wall is only partly zig-zagged .
Second; so are you saying that this is all good? Should I just print it?
Btw I've restarted my configs from absolute scratch since I had problems last with cura giving me very weird time estimates, about a month or so ago. It seems to work OK till now - not sure what to make of it. Do I need to re-create configs regularly for cura not to mess itself up?
GregValiant 1,342
Cura only displays extrusion moves. In your 3mf file "Coasting" is not enabled but those gaps in the images look exactly like what you see when Coasting IS enabled.
Those short travel lines at the end of an extrusion is the move finishing without extruding.
