On 5/20/2022 at 9:05 AM, Pinto-RS2000 said:stions...bump, still need help!
Edited by SFROST2287
Didn’t mean to quote
Newbie here---I tried to work through the online account to see if I could save files on the cloud and pull them down elsewhere, but I can't. Have the exact same issue. Clearly the Linux/Cura/ChromeOS interfaces to not mesh. I'm sure there is a workaround for this issue---just need someone much smarter than I am to help out :)
On 5/20/2022 at 5:05 PM, Pinto-RS2000 said:Help...
I've upgraded from 4.13.1 (which worked faultlessly), to version 5.0.0 the program runs and starts ok! But the open button does nothing! However you can drag and drop a .STL file and it opens it and it slices it fine, however the "save to disc" button (for the GCODE file) again does nothing.. making the program useless.
It's running the ./Filename.AppImage in Linux on a New ASUS Chromebook.
I've tried running the Previous AppImage but that no longer works either.
I've set the file permissions "sudo chmod a+x Filename" and tried "sudo chmod +rwx" still the same issues.
It seems like Cura doesn't know where the default folder. open - save folder is or can't activate the File Dialogue box.
Has anyone got any suggestions or work arounds.
Thanks for any suggestions...
Bump It Still won't work I tried reinstalling it still no joy...
Can anyone help?
UPDATE: I downloaded several of the prior versions, including Beta's to see if one of them would work. Running 4.13.1 works for me. I'm able to click on File> Open and the open dialog box appears. This certainly indicates that there is a bug in 5.0.0.0 that needs fixing.
Same problem. I have an Acer CB314. The install of Cura 5.0.0 went just fine. The program appears to run in every aspect, except clicking on the Open or File> Open does nothing. No dialog box appears, so I can't load or save anything. Upon starting the program from the Linux command prompt I get the following:
PyInstaller/loader/pyimod03_importers.py:495: DeprecationWarning: the imp module is deprecated in favour of importlib and slated for removal in Python 3.12; see the module's documentation for alternative uses
qt.qpa.wayland: Ignoring unexpected wl_surface.enter received for output with id: 7 screen name: "Screen5" screen model: "075A" This is most likely a bug in the compositor.
Cyclic dependency detected between "file:///tmp/.mount_Cura5.aiezrH/share/cura/resources/qml/Actions.qml" and "file:///tmp/.mount_Cura5.aiezrH/share/cura/resources/qml/Actions.qml"
QQmlEngine::setContextForObject(): Object already has a QQmlContext
I hope someone can figure this one out and post either a work around that works or a fix for Cura 5.0.0.
Edited by xf021209
SFROST2287 0
Same issue here. Can’t open or save files. Tried the SD/USB workaround and that didn’t work either.
