Posted (edited) · relative extrusion mode
I think it would be better to put the "relative extrusion mode" in the printer settings section instead of the slicing profile. Maybe also adding a warning while selecting a profile which isn't using the same type of extrusion mode than the printer to ensure retro-compatibilities ...
At the moment, the defaults profiles are set with absolute extrusion mode, and can't be changed. So each time I use a default profile as a starter to make a new profile I must not forget to change the extrusion to relative, that's kind of a trap that should be easily avoided if the extrusion mode is available in the printer settings.
Thanks for your time.
Best regards
Edited by Johnn
