Sending GCODE directly from Python to UM3
burhop
Posted · Sending GCODE directly from Python to UM3
For a research project, I need to stream gcode commands directly to a UM3 from python.
1. I see Python is installed on my UM3 board.   Is there python module or existing code that lets me send the Gcode commands from there?
2. If I was to use the REST API, is there a way to do the same?  The seems to be too high level as I can only send a job, not individual commands.
Thanks for any suggestions!
    Looking though the code, I see how the services work in .../griffin/main.py
    I also see the .../griffin/command_utils.py which has a command to send gcode using these service.  I though I was good so I tried this as a quick test:
    from griffin import dbusif
    def readFromFile(gcodefile):
        file = open(gcodefile, 'r')
        count=0
        for line in file:
            count += 1
            print("Line{}: {}".format(count, line.strip()))
            sendgcode(line)
        file.close()
    def sendgcode(gcmd):
        p=dbusif.RemoteObject("printer")
        p.debugSendGCode(gcmd,timeout=120)
        #p.debugSendGcodenoWait()
    def run():
        filename ="UM3E_cm-cube.gcode"
        print("Executing "+ filename)
        readFromFile(filename)
    Unfortunately, there is no buffering/queueing in the printer.debugSendGCode() command.  All it did was cause the print head to have fits.
    Looking at a lower level, the Printer service uses a Controler object to  send the gcode.  It is has several functions.  SendRawGcode() is what is called by the printer service but I suspect I need it to call queueGcode()
      ## Send raw gcode to the printer. Note that this ignores any paused state.
        def sendRawGCode(self, gcode_line: str, wait=False) -> str:
            # track position in maintenance mode (assumes no other moves are currently in buffer.)
            return self.__gcode_processor.sendInstantRawGCode(gcode_line, self.getGCodeActiveHotend(), wait)
        # @param gcode_line: A string containing GCode that needs to be sent to the driver.
        # @return bool: True if the command was queued for sending as soon as possible. False if the buffers were full or the driver is not connected yet.
        def sendRawGCodeNoBlock(self, gcode_line: str) -> bool:
            return self.__gcode_processor.sendInstantRawGCodeNoBlock(gcode_line, self.getGCodeActiveHotend())
        ## This function is mainly used to queue gcode read from a gcode-file.
        # gcode queued in this way passes through the normal opinicus queue first and is then sent to marlin.
        # When the controller is in a paused state we will blocking wait, unless we are in an un-pausable procedure.
        # @param gcode_line the line of gcode to put in the queue
        def queueGCode(self, gcode_line: str) -> None:
            # only pause if no un-abortable(aka un-pausable) procedures are running.
            if self._abortable.is_set():
                self._running_event.wait()  # Block if the controller is paused
            self.__gcode_processor.processAndQueueGCode(gcode_line, self.getGCodeActiveHotend())
    I hate to muck with the services code and brick my Ultimaker.   Any other thoughts on how to queue up the gcode?
    Posted (edited) · Sending GCODE directly from Python to UM3
    What I thought was no buffering above was a mistake.  I was expecting the printer to pause to heat the build plate not realizing the UM3 doesn't just take a dump of GCODEs from a file.  Darn tricky, these Ultimaker engineers 😉
    It looks like I have to figure out what to do about the header info:
    Edited by burhop
