Cura 5.0 issue - "Wall Ordering" not changing for single line inner wall
Posted · Cura 5.0 issue - "Wall Ordering" not changing for single line inner wall
It seems that the "Wall Ordering" changed to "Inside to Outside" is not changing for single line inner walls (see pics). The classic double inner wall is correctly printed first but then it prints the outer walls, then back to the single line inner wall last..
Going by the "line type" colouring, it is still an "inner wall" but gets printed last (section printed in pic 3).
I have some slight overhangs which would benefit from the single inner wall being printed first.  Is this possibly a bug or is there some setting for the new flow change fill walls?
Thanks,
Philip
    • 2 months later...
    • 2 months later...
    • 1 month later...
    Posted (edited) · Cura 5.0 issue - "Wall Ordering" not changing for single line inner wall
    Still a problem in 5.2.1, I had to increase line width till my single line inner wall was removed for my overhang to print.
    Edited by bobpd830
    Using 5.2.2 and having the same issue. Upgraded to 5.3 and it got worse... Please fix. Cura just ignores wall order.
    If i change "minimum wall line width" to 0.5 * Nozzle Diameter, it prints as expected(two inner walls instead of one), but the surface quality is not good that way because it cant print that small line width accurately...
