OK, playing around with it in perspective mode I discovered that if I de-select the model and then re-select it the model re-centers on the screen. Thanks for your help.
Bill
Rio Rancho, NM
Bill
Rio Rancho, NM
GregValiant 742
There is an option to switch between "Orthographic View" (which doesn't center) and "Perspective View" (which does center). From the Cura Menu it's in "Preferences - Configure Cura - General" under Viewport Behavior. The setting is called Camera Rendering. There is also a button to the right of the "front", "top" and "side" view buttons.
purplegoldwing 0
I have tried both orthographic and perspective view and have exactly the same issue. If you zoom in on a small model on the bed it disappears off the bottom edge of the screen. I see no automatic re-centering. I have selected "center camera when item is selected" but when does it center? I do not see this button you mentioned to the right of the view buttons. Are you talking about the buttons on the bottom left of the screen?
I am using version 5.0 by the way.
Bill
