File not opening
craftythings
Posted · File not opening
I had problems in Cura 4.13 getting a file to open.  So I downloaded Cura 5.0.  It is having the same problem getting anything to load.  Is there a solution for this?
I am using a Creality CR-10spro verion 2.  Any help would be appreciated.
    You are going to have to be more descriptive. What exactly is the problem? What do you do, and what happens?
    It is also useful to know what OS you use.
