Echo:
Rob153
Rob153
     My printer sends a error code.
           Echo: unknown command G11' G10.
I have adjusted my settings to print  a scan of my own art work, a box.
In the settings I unchecked all of the infill commands .All i want is the outline to print.
it is still trying to fill the box. Can any one help?
    G10 is firmware retraction
    G11 is firmware un-retract
    "G11'G10" is not a command and so you got that response.  Check your StartUp Gcode and see if it is in there.  If you are not using "Firmware Retraction" then make sure the "Printer Settings / Firmware Retraction" command is unchecked.
    In the Mesh Fixes section is a setting "Remove all Holes".  Make sure it is unchecked.  There is also the command "Make Overhangs Printable" and make sure that is unchecked as well.
        • 56 replies
        • 29 replies
