QuoteWhat is your total number of extruders?
Do they have separate heaters and nozzles or are they connected to a "multiple-in-one-out" type hot end?
Are you going to want additional "virtual" extruders for color mixing? (your firmware would need to support M163-M166 for that to work).
Thanks for an idea! I'm trying to implement this: https://github.com/Sakati84/3DPrintColorizer
So the total number is 7 (actual extruder + 6 pens).
GregValiant 1,490
There are 3 things you would need to do:
I have my Ender 3 Pro set up for 4 extruders. It was a bit tedious but not really difficult.
Because I made a "local" change to my Cura files, when I update Cura those files have to be copied into the new version. I keep copies available in a separate folder.
