Because the Ender 3 printer will not recognize (they don't show up on the screen) any files from Cura. I WAS able to open, save & print a file under "Prusaslicer". Under this platform, files readily showed up as a print option on the Ender.
In explorer, can you select one of these files Cura creates, and then press Alt+Enter. Post a screenshot of the Properties dialog that opens.
Can you manually rename the file to .gcode? As is, there is no extension.
(Sorry I assumed you were using Windows above, mentioning "Explorer").
ahoeben 2,047
A gcode file is a text file. It just has the extension .gcode
What makes you think this is a problem?
