mouse problems with Cura 5.0.0 and 5.1.0
eagleman999
Posted · mouse problems with Cura 5.0.0 and 5.1.0
Downloaded Cura 5.0.0 and then downloaded Cura 5.1.0 and am experiencing the same problem on both versions, but Cura 4 does not experience the problem.
Using Cura 5.x.x, the mouse sensing is off center when trying to select anything on the screen.  I must place the mouse pointer above and to the right of my desired selection.  For example, in trying to select the "Infill Pattern" the mouse needs to positioned on "Infill Density" and to the right.
This ONLY happens on Cura 5.x.x. and not on Cura 4.x.  Also, this uniformly within Cura 5.x.x whether trying to select a file (upper left) or :Slice" (lower right).  I am operating on a Microsoft Surface Pro 3 with Windows 10 and all of my other programs and functions work fine.
It is annoying to "stab around" with my mouse trying to select necessary fields.
    • 5 months later...
        How to Enter
        Design an Ornament
          Entering a new design
        Entering an existing design
        Winning designs should:
        Be original Creations
        Good luck 🎉
        • 1 reply
        • 13 replies
