GregValiant 1,351
I can tell you what's going on, but not why.
This is an image of your layer at Z=12.0. The circles are drawn around what appear to be simply the ends of extrusion lines. (I know my red text sucks but I'm too lazy for a re-do.)
The text indicates how many ENTIRE lines are within each circle. It does not count the full lines that extend outside of the circle. In a normal situation the count should have been either ZERO or ONE complete line within the circles.
You can see that in the top right circle there are 27 line segments piled on top of each other all at the same Z.
You may have found something here. @nallath could you take a look?. It appears that there is a lot of wasted motion going on and I don't see anything in the Cura Preview because all the lines are colinear. It sure looks like this is what's happening in the OP's GIF video.
Cubic Subdivision Infill.
("Gradual Infill Steps" = 5 but is not visible with Cubic Subdivision.)
Botagar 0
I've recorded a .gif of the layer playback and attached the project file as well.
Any hints or tips?
Thanks~!
CE3PRO_BLOKHEAD.hf.3.30.21.3mf
