cannot print smooth circular surface after update software to 5.0
Posted
(edited)
· cannot print smooth circular surface after update software to 5.0
Check the setting for "Wall Order". If it is "Outside to Inside" then change it to "Inside to Outside". There is nowhere to hide the Z seam on a cylindrical or spherical object.
If you use the "File | Save Project" command and post the 3mf file here someone will take a look.
Remember though, Z seams are like belly buttons, everybody has one. Some (like mine) are just cuter than others.
Edited by GregValiant
GregValiant 1,287
