GregValiant 786
Load the model, set Cura up to slice, use the "File | Save Project" command and post the 3mf file here. Without having an idea of the model geometry it's hard to tell what's really going on.
These sorts of discrepancies are often associated with the Accel (and Jerk) numbers. Depending on the length of a move, the printer may never get near 100mm/sec. In addition, small features (towers, poles, etc.) can cause Cura to bounce off the "Minimum Layer Time" and Cura will slow the print speed down so a layer has time to cool before more plastic goes on top.
At the Ender 3's default acceleration of 500mm/sec² it takes 10mm to get to 100mm/sec and then another 10mm to decel back to 0. So any move that is under 20mm can't hit 100 because it has to start slowing down before it gets to the 10mm point. Consider also that the 20mm movement is "0 to 100 to 0" for an average speed of 50mm/sec.
Within the printer there are Maximum's for Accel and Speed. It's possible to ask Cura to set Accel to 6000mm/sec² and it will go into the gcode that way. Then the line gets to the printer and the printer says "No way...Max Accel is 500" and so the Cura time estimate is way off compared to how long the print actually takes to finish.
My older Ender 3 Pro will print large flat areas at 175mm/sec (over that the extruder can't keep up). For small intricate models I might as well set it to 25mm/sec because it just can't get up to speed. Enders aren't good at high Accel as the stops and starts are so violent that the machine can hurt itself.
So there are limiting factors that go well beyond the settings in any slicer. If you are printing a large square box then you could print it at 100mm/sec and the printer would actually spend time at 100mm/sec. A 10mm x 10mm box you can forget about high speeds as the printer just can't do it.
Now consider those who hang a big direct drive extruder and a gigantic triple fan duct on the print carriage. They might need to drop the accel to 150 to keep from jumping teeth on the belt because of all the weight.
Finally, your printer is a bed slinger. If the Y accel is too high and your print is tall and top heavy then it can throw the print right off the bed. That has been known to happen.
manisland 0
Two more things.
First I have an Ender 3 Max Neo, which I've read should do either 150mm/s, or 120 depending on whom you believe.
Second, if/when I change all the speeds down to 50mm/s (except initial settings) I get 57 minutes, same as 100mm/s.
Thanks!
