Two utterly separate cura instances on same linux PC?
Posted
· Two utterly separate cura instances on same linux PC?
Two different versions of Cura don't share their configuration, so if you run two different AppImage versions of Cura (eg 5.0 and 5.1), they will be independent.
Note that *only* on the first run of a new version of Cura, the application will look for the configuration of older versions of Cura, make a copy of the latest version it can find and upgrade that to its own version and continue to use that. After that, no changes made in the older version will transfer to the newer version and vice versa.
Posted
Thank you, very helpful. Does this apply only to major version differences (4.x vs 5.x), or could the newer instance of cura I add just be the release immediately after the one I've already got, say 4.12.1 and 4.13.1? Thank you.
How to Enter
Design an Ornament
Entering a new design
Entering an existing design
Winning designs should:
Be original Creations
Share the creative journey! Include documentation of your design process, giving us a peek behind the scenes. For example, show a screenshot of the model in your design program. Use the Tag Holidays2023.
Make sure your submission aligns with our guidelines and Thingiverse's Terms of Service.
Good luck 🎉
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
ahoeben 1,890
