Two utterly separate cura instances on same linux PC?
Posted
· Two utterly separate cura instances on same linux PC?
Two different versions of Cura don't share their configuration, so if you run two different AppImage versions of Cura (eg 5.0 and 5.1), they will be independent.
Note that *only* on the first run of a new version of Cura, the application will look for the configuration of older versions of Cura, make a copy of the latest version it can find and upgrade that to its own version and continue to use that. After that, no changes made in the older version will transfer to the newer version and vice versa.
Posted
Thank you, very helpful. Does this apply only to major version differences (4.x vs 5.x), or could the newer instance of cura I add just be the release immediately after the one I've already got, say 4.12.1 and 4.13.1? Thank you.
ahoeben 1,986
