Built plate temperature decreases
AndreaS73
Posted · Built plate temperature decreases
I'm struggling with ABS printing. I guess one of the variables is the build plate temperature, set to 100 °C. I noticed that after some layers it drops down to 86 °C and then the piece detaches. I'm using a Dremel 3D45 with their "purple" glue.
I didn't find the settings where is defined the behavior of this temperature dropping. I enabled the visualization of the all settings, but still I don't find anything related.
Would you please help me to find out this setting?
