Hey Travis3d,
when you do set it up to pause at layer height, when you would restart the print does it go back over the print and extrude out filament? I can't seem to fix this issue ever since 5.0. any thing before that would extrude a little bit out and then move over to the print and resume printing
GregValiant 1,322
My guess is that you have Z-Hops enabled at 0.2 hop-height.
When using "By Height" the plugin (per your example) looks for the first instance of Z=2. If Z-Hops are enabled then the Z-Hop move is the first Z=2 and at .2 hop height the first instance occurs if there is a retraction at the end of gcode Layer:7. It's a known glitch.
Another glitch is when using Adaptive layers because there might not be an exact height that you enter because adaptive layering fudges the layer heights.
"By Layer" works as expected in spite of Z hops or adaptive layers.
