On 8/10/2022 at 2:56 AM, Cuq said:You can try the profile analyser plugin to analyse in your current configuration where is set the output values. Or solution number 2 : I don't need to use the material values and create a profile adapted to each material.
Okay. I will give the analyzer a go. And understood; I know that's an option though one I was hoping to avoid.
Thank you for the feedback!
Cuq 172
