How to rotate my part by only 1 degree in Cura?
Altadis-Alberto
Posted · How to rotate my part by only 1 degree in Cura?
hi, i have Cura version 4.13.1.
When i put my piece in the plate of my ultimaker and try rotate the piece for better position in the plate, but the program only rotate 15º more o less, I can´t rotate one determinate degrees, for example, 72º
    Quick answer: hold down the shift key
    Longer answer:
    There are blue, green, and red arrows.  Click on one of those and release to instantly rotate exactly 90 degrees.  Or click and drag to rotate by steps of 15 degrees.  Or click and drag, then hold down shift key while dragging to rotate down to 1 degree precision.
    Unfortunately I don't know how to go below 1 degree precision.
