Cura changing print temps
kc6331
Posted · Cura changing print temps
I'm not sure why, but when my slice job is set to print at 215, it starts it off at 190 and doesn't change.  Not a deal breaker, but with ABS set at 230, it still defaults back to 190, no bueno.  Any ideas as to why its doing this?  Attached is a cura slice that I had this problem with.
Thanks,
KC
CCR10_Entry_Token_akgmKx.gcode
        • 26 replies
