Thanks for your reply. I started my 7 hour print 10 minutes before I seen your reply. It is still in physical adjustment phase so no big deal. I set the Z Seam Relative and it looks like it moved it inside to a pretty good spot. My object is a bit more complicated than a simple half pipe, sorta like a 3/4 pipe with ramps. I will let you know how the next print turns out. I think it will be very good thank you!
It worked great. Apparently I didn't try all the settings. Z Seam Relative did the trick. Thanks again GregValiant!
- 1
GregValiant 1,322
There are a lot of settings. It takes time to really learn the software and how the settings can affect one another and about all the customization possibilities. I'm not sure how much time it takes...I just know I'm not there yet.
- 1
GregValiant 1,322
It depends on the exact part and the orientation within Cura.
Here is a half pipe with the Z-seam set to Right. The normal situation would be for Cura to put the seam at one of the corners as that is the farthest "right" point on the model.
This is with Z seam "relative", and the X and Y coordinates manually changed to be the part midpoint which in relative mode is the "0, 0" point. So the Z seam will locate in the middle of the inner wall.
I would think you could do that with your model. Most models take some playing around to get the seam where you want it.
Generally it takes me until about layer 10 of a print before I figure it out and have to abort.
Senior moments...ya gotta love' 'em.
