Posted (edited) · Can I import my Cura made Gcode, edit it and resave it?
Is is possible to import my Cura made Gcode, make a slight change, like Temperature, then resave it?
I am able to do this in Simplfy3D by clicking on the "Edit Process Settings" button.
THank you
Edited by Plainbum
added info
    Posted · Can I import my Cura made Gcode, edit it and resave it?
    Hey Plainbum,
    There are several ways to edit your Gcode in Cura there is a post processing script.
    But I believe that doesn't work when you load in Gcodes.
    Gcodes are basically textfiles. You can also use programs like Notepad or Notepad++ to make changes and save the file.
    But you will have to know what you are looking for. It helps if you check your gcode flavor.
    For this Ultimaker 3 Extended, the flavor is Griffin.
    So with a page like https://all3dp.com/2/3d-printer-g-code-commands-list-tutorial/ I can find the commands I am looking for.
    I hope this helps. Good luck!
