Posted · Exact size of Ultimaker 2 glass printbed
Hello,
can someone please do me a favour and give me the exact measures of the glass printbed of the Ultimaker 2?
I would like to build me a glass printbed for my Ultimaker 1, which should also fit to the factory mounts of my future Ultimaker 2.
Thanks in advance!
    the glass plate on the Ultimaker2 (at least on mine) has the following dimensions:
    Length (from front to back): 22.7cm + 0.1 at the back and front each where the glass is beveled = 22.9cm
    Width (from left to right): 25.5cm + 0.1 at the left and right each where the glass is beveled = 25.7cm
    Height: 3.86mm - 3.88mm (it is not 100% even as it looks)
    Height was measured with a caliper, all others with measuring tape
          • Heart
        • 4 replies
