It seems the definition on the body is more defined than the text according to the setting I made in the blocker. Does the blocker not affect the text? Do you see that also? You mentioned an additional blocker just over the text with settings just for the text correct? So one blocker can be within another? If I were to do this would I need a custom blocker? If so, can you direct me to how to make a custom blocker if that is the case.
I realize there will be visible lines but I want to try to get it as good as possible. Nice thing about fuzzy skin is it doesn't have lines :-)
Kotaztrafee 2
